сделал запрос производителю, рекомендуют поменять ДИПы
нет времени толком переводит с англ, дальше кидаю текст письма
Hi,
According to the latest Gateway Five firmware versions, there is an alternative DIP setting available for Audi users
when the phone menu cannot be selected from SWC.
I have attached the description, how to do that.
Please check (test if possible) and let us know about the results.
Kind regards,
текст во вложении:
Special release note for Audi:
The latest firmware release of Gateway Five (GWF) has a special feature for Audi users (GWF1AC1/AC2)
Use the recommended modifications and steps below if you experience problem with accessing the phone menu and different phone options like phonebook, call history etc.
Follow the steps below to update firmware:
Extract the G31a_upd.rom file from the update package, copy the file to the root of a USB flash drive
and then connect the USB drive to the Gateway Five’s while it is powered up (ignition ON). If possible
please also copy 2-3 MP3 files to the USB device, again to the root.
If there is an iPod connected to Gateway, please disconnect it before you connect the USB drive.
The update procedure will start automatically within a few seconds and takes approximately 2
minutes. During the update procedure the Gateway Five will restart a couple of times. Do not
disconnect the USB drive within this time (!).
When finished, you may need to reselect Gateway again from the headunit.
After a successful update the G31a_upd.rom is deleted from the USB flash drive and the new
software version number will be visible in the Gateway Settings\About menu.
Please test the Gateway functions (iPod & USB). If these functions works properly, please change the DIP switch settings to 2,4 ON (others OFF)
on the Gateway. After the reconfiguration, please press the reset button on the connector port or disconnect and reconnect the hardware from the power.
When finished, please turn the ignition and Head Unit ON and test the GAteway Five, especially the Phone functions.
If you experience a major problem while you are using the new DIP switch settings in that case please set the DIP switches back to the original (previous) state and press reset on the connector port or disconnect the HW for 5 seconds then reconnect.
We do appreciate also if you can give us a feedback about the result, therefore please go to
www.dension.com click on 'Support' and create a support ticket.
Please note:
Although we do support playing music content from a USB hard disk drive, for the
firmware update please use a USB flash stick/pen drive.
